pendean
en respuesta a: ktoofanPA8SX
So you might try a Microstation Support forum for issues within that program https://communities.bentley.com/products/microstation/f/microstation-forum
But I will assume if the xref files are loaded/present in the top file, then you either have a layer off issue, the xrefs need to be reloaded (think AutoCAD's unload option in XREF, but the reverse), or they are out of view (you have a floating element too far away from your content).
