TheCADnoob
en respuesta a: Anonymous
If its the PDF lines check out this thread:https://forums.autodesk.com/t5/autocad-lt-forum/problem-pdf-print-generates-strange-lines-over-hatch...
Also a possible solution:
"The problem is still happening, even in ACAD2016 - but the solution is simple, instead of using solid or small size ansi hatch, use gradient with two same colours. No strange lines."
CADnoob
