386 Vistas, 3 Respuestas
Display more dropdown options.
I'm following a homework tutorial from my civil engineering tech class and it asks me to select the icon POINTS from the "Draw" dropdown. I only see, spline fit, spline cv, consturction line, ray, multiple points, divide, measure, region, wipeout, 3d polyline, helix, donut and rectangular revision cloud. So I'm unsure how to display more icons or is that all there is. The icon in the tutorial shows just one small hollow point and the only icon that I would think is similar is the multiple points icon. Thanks for your time.
awood
en respuesta a: Anonymous
If all else fails type POINT <enter> at the command line.
You can also set a point style with the DDPTYPE command.
HTH
AWoo
Patchy
Ribbon might be different than Toolbar, yes, if nothing there use Commmand :  POINT
or customize your ribbon to add POINT
M_Hensley
Point is on the draw pull down menu, not the ribbon. To see the menu type MENUBAR and set it to 1.
