617 Vistas, 8 Respuestas
Unable to edit blocks
Hey guys I've run into an interesting problem here...
I just switched computers with someone else in my office and had to re-download AutoCAD 2020. All of my files were transferred over along with all my existing settings on my previous computer. When I got back into the program I was unable to edit my blocks. I've tried opening some old drawings and it's the same issue with every file.
I've tried editing my double click function for blocks to open the block editor, which is the way I always access it. This didn't work.
I also tried to use different commands such as "BEDIT", ".BEDIT", and "._BEDIT". None of these commands worked either.
Also, my "BLOCKEDITLOCK" is already set to "0" at the moment.
Before I switched computers I updated to the latest version... even with the latest version I noticed a few other small differences even though I'm up to date still. My lineweight displays looks a little different and some of the color settings are different in my model space. Other than that everything seems to be the same.
Has anyone run into an issue similar to this or already have a possible solution to this problem?
Any help is greatly appreciated!
-Josiah
