Alfred.NESWADBA
en respuesta a: Anonymous
sounds that your displaylist was not updated with the new geometry.
Which version of AutoCAD are you using (command _ABOUT) and which graphic card and driver are you using (command _GRAPHICSCONFIG).
When you turn off hardware acceleration (command _GRAPHICSCONFIG) does the graphic then behave better?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
