10-19-2015
07:28 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-19-2015
07:28 AM
The only way to have the text boxes scale is to have the MTEXT set to either no columns or static colmumns, neither of which would probably work for you if the formating has to stay the same. One other thought that might work for you is to use the UNITS command and change the insertion scale to nonameters before you insert their dwg. That will bring the dwg in already scaled down by 1000 and the text boxes will be right.
