Kent1Cooper
en respuesta a: Anonymous
@Anonymous wrote:
Each segment of the green polyline is exact 980 (except the last remainig) and each endpoint of the line segments touches the blue source curve. Is this what you want?
This is exactly what I want! Thank you Jurgen
I think I know the answer to this, but just for clarification....
Compare these results on the Polyline in white at left [deliberately more convoluted than your example, to illustrate the difference better]:
In the middle is @j.palmeL29YX's method, using the blue Circles so that the segments of the red result are of equal length.
On the right is a different approach, using MEASURE to place the yellow Points, and drawing the green result between those.  The Points are spaced at equal distances along the original path, which means [because of its convolutions] that the segments of the green result are not  all of equal length.
The difference between red and green here is pretty obvious -- it would be less so in a situation like your example, but still there would be a difference.
The reason I ask for the specific clarification is that a routine to produce the green result on the right would be enormously easier  to write than one for the red result in the middle, if that green kind of result is acceptable.
Kent Cooper, AIA
