- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
How to deactivate orto modus completely
Hello and sorry for asking that Kind of Question but...
I deactivated the orto Modus but i can still only draw in direction of x and y.
If i try to draw a square from the left or right it appears as a simple line.
Further i can spin things only in the x and y Level.
Does someone has a clue wich Setting is wrong?
Again, sorry but i couldt not figure it out by myself.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"but i can still only draw in direction of x and y."
Wrong. Try it with a LINE or 3DPLINE ![]()
Some command/object you only can create in the current UCS.
PLINE or CIRCLE for example.
So deal with changing the UCS -> command UCS.
or create the object an edit them by 3drotate or 3dalign ..
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
you need to change the UCS to world mode then type PLAN command >> double enter.
Command: UCS
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: w
Command: PLAN
Enter an option [Current ucs/Ucs/World] <Current>:
Regenerating model.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This solution seems to be a good way but it does'nt Change the fact i cant draw for excample a square or circle from left or right....right!?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
is it applicable please to attache here your drawing to see what you see ?
Imad Habash
