j.palmeL29YX
en respuesta a: Anonymous
@Anonymous wrote:
Is there a way I can convert a polyline to equal straight segments?
I've attached a drawing to explain,
Sorry, I still do not understand what you need.
First: The blue geometry in your dwg is not a polyline, but only some arcs. But thats not my problem.
To illustrate my question I show a >>video>>.
The blue curve is your "curved line" - ok.
The red (I changed the color) is your faceted polyline. If I move the red pline to the blue curve, they do not match each other. The polyline segments don't touch the blue curve. And also, the length of the PL-segments is far away from 980 and each of the segments has another length. What now???
How I understand your intention I would expect a result as shown in my green polyline. Each segment of the green polyline is exact 980 (except the last remainig) and each endpoint of the line segments touches the blue source curve. Is this what you want?
I have not yet a solution how to create this in an easy quick way, but first I try to understand what you expect to get.
Jürgen Palme
