11-26-2019
02:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-26-2019
02:00 AM
About import script to Autocad and about "ROTATE"
Dear all,
I a new user of autocad.
I search something on internet and found the following script.
How can I import to my autocad and use it?
Another thing is,
I want to know something about ROTATE~
I found that when I use rotate common, after I choose the based point. the routine of the starting point will be on 15 degree everytime.
Can I rotate that from the point that I want?
Look forward to received any solution~
Thank you~
Tammy
;* Rotate Multiple ;* Rotates many entities around their respective basepoints ;* allows selection by AUTOCAD selection sets or SSX. ;* Written by David Husch, January 1991 (defun c:rotmult () (prompt "Select Entities to Rotate, <ENTER> for SSX.") (setq ss (ssget)) (if (not ss) (setq ss (ssx))) (setq num (sslength ss)) (setq x 0) (if ss (if (setq ang (getreal "Enter Rotation Angle: ")) (repeat num (setq ename (ssname ss x)) (setq elist (entget ename)) (setq pnt (cdr(assoc 10 elist))) (command "Rotate" ename "" pnt ang) (setq x (1+ x)) ) ) ) )
