en respuesta a: JTBWorld
Hi Jimmy,
Apologies for the mistake. Please visit the link again. The shared folder is populated with zip files now.
Also, i investigated it further. I copied the whole project folder to a different HDD (different physical HDD & not just different partition of HDD) which is not made to sync with Google drive. It was done just to check if Google drive is causing problem.
I opened the dst file from new location and again rename and renumber option was grayed out.
I am now confused. If it was caused by Google drive, then the problem shouldn't had popped up at new location but it did.
It seems there is some issue with Cad and/or folder structure which is being repaired/corrected when a etransmit being saved?
