en respuesta a: JTBWorld
ok... so I dug in a bit more on this matter and here is what I found.
1. I etransmit the whole SSM and every file in it. Then I unzip the etransmit package and i access those SSM & Cad files. There, I can rename & renumber easily.
2. if i copy back all the CAD files & SSM file from the unzipped etransmit folder into original location, the rename & renumber option again becomes greyed out.
the original location is set to have backup and sync with google drive. is it causing the problem? I can't narrow down it anymore. any bright ideas here?
