en respuesta a: Anonymous
Hi all,
1. Yes. I can rename CAD file in windows explorer. I can even rename layout manually when the file is open in AutoCAD - however not through the SSM.
2. And yes i second that thought that no matter CAD file is open somewhere or not, you can always rename layout within SSM - at least you should be.
If it helps, i can upload the etransmit  where you can see the problem. 2 of the drawings in the same file - which were added 3 days back into the SSM - can be renamed and renumbered very easily within SSM but rest files - which are present in SSM for last 2-3 months - can't be renamed.
Also, for information,the whole folder of drawings has been made to sync with Google drive using Google back and sync although i don't think it is causing the problem because if it would, those 2 drawings added in SSM later on would also had got affected.
