en respuesta a: vinodkl
I used a pdf as an underlay in a drawing. And used that drawing as an Xref. But it also works when I put the pdf directly into a block the same way I did with the Xref.
But I just found out that the pdf in Intellicad behaves differently from Autocad software. I opened the drawing (dwg-file) I made with Intellicad with a Autocad viewer from Autodesk and the gridlines were visible through the Xref. In Intellicad the grid lines ar not visible and the Xref is seen as the drawing on the original pdf file, but with a solid black background. That's the reason I can select it by accident and the objects on the drawing disappear in to the background. I have put some screen shots to show you what I mean. Left is Autocad viewer, right is Intellicad.
Autocad exampleAutocad exampleIntellicad exampleIntellicad example
Unfortunately I don't have original Autocad software at my disposal to test it. I suggest I leave it to rest, because it the issues with Intellicad software apparently don't correspond with the Autodesk software. Sorry I wasted everybody's time. :cara_guiñando_un_ojo:
