vinodkl
en respuesta a: Anonymous
@Anonymous wrote:
Hi CADffm,
Thanks for your reply! To bad that this doens't work in autocad. The main reason for me at the moment is that I'm using a pdf as an underlay. If I want to select multiple objects that are drawn on the pdf, the pdf underlay always gets selected and the objects disappear while the pdf is selected.
Are you sure your using the PDF as underlay as I have never come across this type of behavior of object disappearing when pdf is selected, because this type of behavior is happens when you working with OLE underlay.
Did you use the command "PDFATTACH" to attach the PDF into the drawing?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
