- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi CADffm,
Thanks for your reply! To bad that this doens't work in autocad. The main reason for me at the moment is that I'm using a pdf as an underlay. If I want to select multiple objects that are drawn on the pdf, the pdf underlay always gets selected and the objects disappear while the pdf is selected. Wherever I click it gets selected which makes drawing pretty difficult. And that's why it's important for me that the pdf is not editable AND not selectable. But it could be some Intellicad problem. I'm using it for the first time since a couple of weeks. However I prefer to have the option to make a xref not selectable so it doens't happen by accident.
I have used autocad at my previous employer, but I hadn't used a pdf as an underlay before. So the problem never occured. However, for some reason this works for me and apperently locking the xref layer is a proper solution for everybody else.
have a good day!
