sterling.parker
802 Vistas, 3 Respuestas
FIND only returning one instance out of many blocks with the same text
I'm running into a strange issue where the FIND command, given some text, will only find that text in one placed instance of a block, though I have multiple blocks of that same kind in the drawing. In any case, it seems to be the oldest instance. Changing criteria for FIND fails to change results. Drawing file attached.
Example: I have a block "CardReader" with the text "CD" in a rectangle. If I use FIND for "CD" it only returns one block, the oldest one. If I delete and insert a new instance of that block, FIND then returns, again, the next-oldest instance.
Product Version Q.103.0.0 AutoCAD 20.20.1
Possible Bug? So far as I can tell, this is just with text in blocks so far. Text outside blocks is still found correctly.
Etiquetas (3)
