mhathawayMMW
330 Vistas, 1 Respuesta
LISP has never run, brand new to the idea please help
I have been learning some tutorials on 3D modeling in AutoCAD.
Currently my company has begun to use a program called Microvellum, and i cant seem to get the LISPs to work.
When i try to run the LISP; pressing "Visual LISP Editor" or even "VLISP" i tend to get an error which reads,
"Cannot invoke (command) from error without prior call to (*push-error-using-command*). Converting (command) calls to (command-s) is recommended."
I am sure i am not the only one who has done this, yet i have read up on as few other forums but none seem to touch upon details a beginner may understand. I have little to no coding training.
Any advice is helpful.
Etiquetas (2)
rue.williams
en respuesta a: mhathawayMMW
Hi @mhathawayMMW ,
Thank you for your post. You might get a quicker response to your issue if you post it in the LISP forum
Rue Williams
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
