pirkmajer.lea
254 Vistas, 1 Respuesta
AutoCAD becoming barely responsive after mirroring shapes
While working on a project I drawn a shape and then mirrored it quite a few times to make a pattern. Now the problem is that AutoCAD became barely responsive. I can barely zoom in and out, it stutters and lags so much it's not usable. I'm using a 6 core, 16 GB macbook pro, and AutoCAD is utilizing 5% CPU and 5% RAM.
Is this a software problem or can this be achieved in some other way?
The project file is attached. Thanks!
en respuesta a: pirkmajer.lea
For some reason you have your visual style set to "shaded with edges". None of this geometry is 3D, so if you just change your visual style to 2D Wireframe, it works fine.
