TerryDotson
en respuesta a: subramanian.nanda
After clicking the icon (inside your drawing), use the pull down in the upper left to select [Layers], then put a checkbox in each layer you want to export (space bar works well), verify your output path and choose [OK].  It should create a drawing file for each layer in the target folder.
