rkmcswain
en respuesta a: Anonymous
1. Run the MENU command, and load the menu:
"C:\Users\<your_user-name>\AppData\Roaming\Autodesk\AutoCAD 20xx\Rxx.x\enu\Support\acad.cuix" (items in blue will vary per user/version of CAD)
2. In your example, that prompt is just part of the Mirror command. Perhaps you were using a menu macro or lisp routine that filled in the answer for you.
