Automohan
645 Vistas, 5 Respuestas
Command List
Please anyone share with me AutoCAD 2017 Command Lists
I am using civil 3D as AutoCAD 2017
I would like to know civil 3D as AutoCAD 2017 & the single AutoCAD 2017 both are exactly same program?
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Etiquetas (1)
ennujozlagam
en respuesta a: Automohan
you can try this in the command prompt type ARX > C (commands) > enter > enter.....and see if helps. thanks
ВeekeeCZ
Almost the same.
C3D as ACAD loads plenty of C3D stuff so it's significantly slower than vanilla ACAD.
pendean
No difference with core autocad commands: ask in the C3D dedicated forum for more info if you think you are missing something specific https://forums.autodesk.com/t5/civil-3d/ct-p/4003
GrantsPirate
http://help.autodesk.com/view/ACD/2017/ENU/
Help file for plain AutoCAD 2017, commands will be shown there.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
ara_neresesian
HI
Yes They are.
you can run Civil 3d as autocad(this optin will work faster by unloading the unnecessary arx,lsp,.....)
Please select the Accept as Solution button if my post help to solves your issue or your question.
good luck
