11-13-2019
01:08 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-13-2019
01:08 PM
This may be a silly question, but in notepad, when you hit "file" then "open" down towards the bottom right of the dialog box, where it shows "Text Documents(*.txt)" did you expand that box and pick "All Files(*.*)" option?- otherwise all you will see in any folder are .txt files.....If you select the all files option, you should be able to see and edit just about any type of file on the PC...at least you found a workaround for this episode, but that may help for future issues...
