RAFUSE
en respuesta a: Anonymous
Danial,
Thanks so much for your reply!
I just ran notepad in "run as administrator" and tried to open C:\Program Files\Autodesk\AutoCAD 2020\Support\acaddoc.lsp, but in the open file dialog, nothing showed to open, only sub folders!  Only if in file open dialog by entering :C:\Program Files\Autodesk\AutoCAD 2020\Support\acaddoc.lsp would it open up and be able to save.  Never had to do this ever!
One could say I found a "work around" for the Win 10 issue, but . . .  But this "fix" didn't work with edit pad (which is a great text editor!)  If I try to save as another file name, I am told I don't have permission to same in this location.
I just noticed this, when I right click on preferences for the mother folder , the attributes show as read only.  I uncheck it, pick apply, the read only box is cleared, and close the dialog.  Pop-ups show the attributes being changed.  But, going right back to preferences, the attributes show read only again.  What gives?
I know many are running Win 10, but I never had these issues in Win 7.  Win 10 seems to have way too many settings and sub settings.  All I want to do is use the computer to run an engineering business, not fight the OS!!!!
I just changed the attribute only for the individual file, and I was able to save my changes.  @*#$%&*!!  Go figure.
Richard
