vinodkl
en respuesta a: DartGTDan-2018
You can drag and drop the file (linout.vlx)into AutoCAD drawing from which you want to extract the line types and then type in the command LINOUT. now the line types used in the drawing will the exported into .lin file into the same location where the drawing is.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
