piyinghai
139 Views, 3 Replies
Need Help-How to change Model Tree hierarchy of Navisworks ?
I imported my files from Revit into Navisworks. The selected tree structure is fixed and cannot be changed.I try to change porperty.Value , But not modifiable.I need to render the selection tree of Navisworks based on the data I entered in Revit.
  I've seen someone implement choice tree structural refactoring as below:
 But I don't know how to do that.like below
Please help me. Best wish !
Labels (2)
naveen.kumar.t
in reply to: piyinghai
Hi @piyinghai ,
To the best of my knowledge, it is not possible to modify the Model Tree hierarchy in Navisworks. However, you can sort the existing Model Tree hierarchy or create a custom selection tree.
Please refer to the following links for more information:
https://adndevblog.typepad.com/aec/2013/04/use-navisworks-api-with-wpf-binding-model-hierarchy-to-tr...
https://forums.autodesk.com/t5/navisworks-api/sort-navisworks-model-tree-through-commandline/td-p/12...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
piyinghai
in reply to: naveen.kumar.t
Thanks for your reply, I need to have a try. Before that, I would like to ask if the results achieved by this article are as follows, is it the result under the standard mode of Navisworks' selection tree?
naveen.kumar.t
Hi @piyinghai ,
In your previous post, the attached image shows that I simply selected the standard mode and sorted the selection tree in ascending alphabetical order.
Naveen Kumar T
