AUTODESK EXPERT ELITE
157 Kudos
199 Solutions
Re: How to get a list of Schedule Style defined in the drawing?
02-18-2013 07:36 AM in reply to: Keith.Brown
I thought i might add that if you download the AutodeskMGDDBG application from this link.  It will allow you to "snoop" an object or a database and see all of the named object dictionaries in the drawing.
You can view this webpage to download the file instead of the direct link above if you prefer.
http://adndevblog.typepad.com/autocad/2012/04/dwg-debugger-mgddbg-app-for-autocad-20122013.html
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2016 | CADWorx 2015 | Revit 2016 | EastCoast CAD/CAM V6.1 | Visual Studio 2015
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
View solution in original post
