paullimapa
en respuesta a: SOMITBHARDWAJ
So you can decide that your projects primary measuring units is in Karam using Length type as Decimal units. So you can draw an object thats 1 karam units long. But you can show the alternate measurements in inches by defining that in your Dimension Style (DDIM command) which can be set to show Karam as the primary dimension while Inches as the secondary dimension.
Paul Li
IT Specialist
@The Office
