maxim_k
en respuesta a: emma_whiteW4Y7M
@emma_whiteW4Y7M ,
If you want to use specific SHX file provided by your Prof. with some drawing, you need to put this SHX file inside
/Users/emmawhite/Library/Application Support/Autodesk/AutoCAD 2025/R25.0/roaming/@en@/Support/SHXFont
folder, relaunch AutoCAD and open your drawing. Texts in the drawing should now display correctly.
To open the folder I mentioned above - use menu Go -> Go to Folder... in Funder. Copy the path:
 paste it to Go to Folder... window and hit Return.
Now you can place the SHX file into the Finder window that opens.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
