emma_whiteW4Y7M
1031 Vistas, 24 Respuestas
SHX Font File not opening
Hi! I am using AutoCAD for a college class. I need to upload a file to insert premade fonts for my assignment via AutoCAD. Although, I can see the files but AutoCAD won't let me open them. The error message says, "Cannot find the specified drawing file. Please verify that the file exists." Do you know how I can fix this? I am using AutoCAD for Macbook 2025.
maxim_k
en respuesta a: emma_whiteW4Y7M
Hi @emma_whiteW4Y7M ,
On the screenshot you attached I see autoCAD settings window and looks like you are trying to change one of the Support Files Search paths - the path to SHX folder.
Can you show the window with the alert you mentioned in your post - "Cannot find the specified drawing file. Please verify that the file exists." At what point does it appear? What are you trying to do at this moment?
Can you provide more details?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
emma_whiteW4Y7M
en respuesta a: maxim_k
Hi, thank you so much for relying to me!!!
The Error message appears when I try and open the SHX file. It takes me directly to AutoCAD with the error message I attached below.
Please let me know if this helps, I am very new to AutoCAD. My Prof. say's she has no idea how to fix this.
paullimapa
Shx files are not drawing files
Dwg files are AutoCAD drawing files
To use shx files with an AutoCAD dwg file use the Style command and create a new text style selecting the shx file as the font and then use the Text or Mtext command to enter text using the new Style you created
Paul Li
IT Specialist
@The Office
maxim_k
@emma_whiteW4Y7M ,
If you want to use specific SHX file provided by your Prof. with some drawing, you need to put this SHX file inside
/Users/emmawhite/Library/Application Support/Autodesk/AutoCAD 2025/R25.0/roaming/@en@/Support/SHXFont
folder, relaunch AutoCAD and open your drawing. Texts in the drawing should now display correctly.
To open the folder I mentioned above - use menu Go -> Go to Folder... in Funder. Copy the path:
 paste it to Go to Folder... window and hit Return.
Now you can place the SHX file into the Finder window that opens.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
paullimapa
FYI, OP shows that those are already in that folder: simplex.shx & gdt.shx
Paul Li
IT Specialist
@The Office
emma_whiteW4Y7M
en respuesta a: paullimapa
Hi Paullimapa.
They are in the folder. Although, AutoCAD will not let me open either of them.
maxim_k
@paullimapa ,
simplex.shx and gdt.shx are standard AutoCAD for Mac SHX files, they are in that folder OOTB.
Looks like OP's Prof. sent him a different SHX file.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
emma_whiteW4Y7M
Could you explain how I would do this? What is Menu Go?
Thank you!
maxim_k
@emma_whiteW4Y7M ,
You don't need to open ore edit these SHX files, AutoCAD will handle them on its own.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
@emma_whiteW4Y7M
How you will do ..... what?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
@emma_whiteW4Y7M
Another way to install SXH files to AutoCAD for Mac:
How to install a font into AutoCAD for Mac
Look for the steps about SHX files.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
paullimapa
As I replied. AutoCAD do not open shx files. Have you tried the Style command?
Review this video tutorial starting at 54:09 timestamp:
https://www.youtube.com/watch?v=jSZOcSagios&list=PLkRa_lfE2jnuXruLVUI8y_P3TrJwIG7Yk
Paul Li
IT Specialist
@The Office
emma_whiteW4Y7M
Thank you for this video, paullimapa.
Please look at the screen shot I have attached below. It looks like these are labeled the same as my file? Archstyl & shx.
I appologie that is the wrong image, below is the correct image.
paullimapa
Looks like ARCHSTYL is assigned with archstyle.shx and bigfont @extfont2.shx...and your question is?
Paul Li
IT Specialist
@The Office
emma_whiteW4Y7M
I need to have these fonts as shown in the attachment below. The attachment is my prof. AutoCAD screen. I should have RMCAD_64, RMCAD_96, etc. Those are not showing in the...      format - text style list.
I guess I am still confused on how to get the preloaded fonts within the Archstyl.shx file.
I apologize for the confusion, I have no idea what I am doing and am trying my best to make sense!
paullimapa
Those are dimension styles and not text styles. Ask your professor to explain the difference. If there are additional custom fonts your professor is using with a dwg then your professor should consider using the etransmit command to create a package that will include all fonts used for you.
Paul Li
IT Specialist
@The Office
emma_whiteW4Y7M
Ok , thank you for trying to help me figure this out.
maxim_k
@emma_whiteW4Y7M
Please find Archstyl.shx in the attached archive, extract it to some folder inside your home folder and follow instructions from:
Relaunch AutoCAD and open your drawing, now this font will show correctly.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
