maxim_k
en respuesta a: karahandemir
Hi @karahandemir ,
Can you share the AutoLISP file itself?
Why do you think the new command that is added after loading this AutoLISP file is COUNT?
COUNT is the internal AutoCAD command:
https://help.autodesk.com/view/ACDMAC/2025/ENU/?guid=GUID-85CCF100-3799-4BCE-AE95-245D770B5046
To find out the command that is defined in this LISP, you need to open it in a plain text editor and find the line:
(defun C:
The word after C: is the new command name, which you need to use.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
