karahandemir
530 Vistas, 8 Respuestas
LISP file not opening on Autocad2025
When I drag and drop the LISP file into AutoCad 2025 it doesn't work. I don't get any errors. I uploaded a video for this issue.
Etiquetas (2)
Etiquetas (2)
maxim_k
en respuesta a: karahandemir
Hi @karahandemir ,
Can you share the AutoLISP file itself?
Why do you think the new command that is added after loading this AutoLISP file is COUNT?
COUNT is the internal AutoCAD command:
https://help.autodesk.com/view/ACDMAC/2025/ENU/?guid=GUID-85CCF100-3799-4BCE-AE95-245D770B5046
To find out the command that is defined in this LISP, you need to open it in a plain text editor and find the line:
(defun C:
The word after C: is the new command name, which you need to use.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
paullimapa
The answer to your problem is as shown in the command line response after you attempted to load the lisp:
vl-load-com function which this lisp requires is not supported on the Mac
Paul Li
IT Specialist
@The Office
karahandemir
en respuesta a: maxim_k
Thanks for your answer, I'm adding LISP
karahandemir
en respuesta a: paullimapa
is there a solution to this? I cannot use any LISP files that I use in Windows operating system in macOS operating system :cara_de_decepción:
paullimapa
One solution is to look for lisp routines that are supported on the Mac version of AutoCAD which don’t require vl functions.
Paul Li
IT Specialist
@The Office
paullimapa
As @maxim_k responded why aren’t you using AutoCADs built in Count command?
Paul Li
IT Specialist
@The Office
karahandemir
because this creates a table with block images for me and makes my job easier. I also wrote it here because it doesn't work not only for this LISP, but also for multiple LISP files I use. Thank you..
paullimapa
There are just lisp support limitations on the Mac version where the only work around would be to continue to use the Windows version of AutoCAD on the Mac by running Parallels
Paul Li
IT Specialist
@The Office
