joW8BBH
315 Vistas, 4 Respuestas
Autocad LT 2025 Mac - How to turn off DSD save when plotting
Is it possible to disable the DSD prompt when plotting as it pops up everytime I plot, thanks.
Using LT so "hidden message" tab not available, tried "Reset hidden messages", still not working.
Many thanks
maxim_k
en respuesta a: joW8BBH
Hi @joW8BBH ,
Have you tried this option?
 >>>>>Using LT so "hidden message" tab not available, tried "Reset hidden messages", still not working.
If you want to get back the dialog box shown above you can use "Reset hidden messages" on Application tab of AutoCAD Preferences.
If this doesn't help, you can try to quit AutoCAD, trash Profile.aws file inside
"~/Library/Application Support/Autodesk/Autocad LT 2025 Standalone/R24.1/roaming/Support"
folder, then relaunch AutoCAD.
Not sure about Autocad LT 2025 Standalone, but you can check the name yourself - it should contain Autocad LT 2025
~/Library - means Library folder inside your Home folder and it is hidden by default.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
joW8BBH
en respuesta a: maxim_k
Hi there, thanks for the suggestion, I've managed to get as far as
"~/Library/Application Support/Autodesk/Autocad LT 2025 Standalone/ --> then it only has a UPI folder with ODIS_UPI2_BOM.xml?
Am i doing something wrong? Thanks!
maxim_k
Hi @joW8BBH ,
You've come to the wrong place.
As I wrote before, you need to get to the Library folder inside your Home folder (User Library folder), but get to the library folder in the root folder of your Mac drive.
  1. Click 'Go' in the Finder menu bar, and hold down the 'Option' (Alt) key.
  2. The Library entry now appears in the Finder > Go menu.
  3. Clicking Library directly opens the hidden User Library folder in a new Finder window.
  4. Now you can navigate to the rest of the path: "Application Support/Autodesk/Autocad LT 2025 Standalone/R24.1/roaming/Support"
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
joW8BBH
Thats just solved the issue, thanks a lot!
