CMINNICK37F3QE
255 Vistas, 5 Respuestas
Scale line weights in viewport without changing viewport scale
The CTB I use is perfect for 1'4"=1'-0" floor plans. If I have to print at 1/8", the line work gets muddy. How can I control the line weight of a single viewport? In Vecrtorworks, for example, you select the viewport and tell it to print lines at 50% . . . while keeping the drawing scale in tact.
