moneumiko
en respuesta a: maxwinkens
Did you even try Maxim's solutions?
Your problem is super easy to fix, in many different ways. I looked at your file, and what I did was use a layout with a viewport to print to PDF. You double-click the viewport, and in the layer manager you change the colours of the layers (the viewport colours, not the main ones) where you need to use a different colour (I put your texts to the 003_text layer, and lines to lines layer. Why did you put everything on 0?)
