neillyditt
319 Vistas, 4 Respuestas
Separate drawings on separate screens
I have a two monitor set up and wondered whether it was possible to have two drawing files open on separate screens?
Any help gratefully received.
Neil
maxim_k
en respuesta a: neillyditt
Hi Neil,
You can open new AutoCAD Session from Dock (right-click) and drag the new session to another monitor:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
the AutoCAD4WindowsOS ability is not available in the AutoCAD4MacOS if that is the tutorial you watched online @neillyditt
neillyditt
en respuesta a: maxim_k
Hi.
Thanks for this.
That was super helpful, but I have noticed that since using the New AutoCad Session option, every time I now open my software it thinks that it hasn't shutdown correctly and wants to open recovered files.
Is there a way that I can correct this?
Neil
maxim_k
Hi Neil,
@neillyditt ,
Try this:
Set System variable RECOVERYMODE=0. This will prevent  Drawing Recovery window automatically appear after a system failure, and should remove any recovery information in AutoCAD.
Now set RECOVERYMODE=2 (default) and test new session behavior.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
