pendean
en respuesta a: NYSmokepipe
No, that's not a thing in AutoCAD, unless you give up on all annotative TEXT and dimension styles all the time, aka go old school, then suffer through manually changing those styles every time you have a viewport scale change.
Why not work in modelspace instead? Or go inside the viewport's modelspace using VPMAX command?
