takeda.electric.osaka
400 Vistas, 5 Respuestas
画層印刷設定
一部の画層を印刷しない設定にしたら、全ての画層が印刷しない設定になり、元にも戻せない。
Should be able to use Layer Properties Manager, highlight the layers you want to plot again and select under the Plot column
Paul Li
IT Specialist
@The Office
何も解決しませんが。
Mac AutoCadですが。
maxim_k
en respuesta a: takeda.electric.osaka
Hi @takeda.electric.osaka ,
Please specify AutoCAD for Mac version you are using and macOS installed on your Mac.
Can you share screenshot of the Layers Palette which shows this issue?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Sonoma14.5
CAD R.47.M.224
maxim_k
@takeda.electric.osaka wrote:
Sonoma14.5
CAD R.47.M.224
Looks like you have AutoCAD 2021 for Mac. Isn't it?
If so - then this version is not supported on macOS Sonoma, the latest version of macOS that supports AutoCAD 2021 for Mac is macOS Ventura.
You need to upgrade AutoCAD at least to 2022 version. If you are on subscription you can install AutoCAD 2025 for Mac, which is fully supported on macOS Sonoma.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
