05-20-2024
01:17 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-20-2024
01:17 AM
Hi @maryada_k ,
1/ To enable relative coordinates for direct input use menu Tools -> Drafting Settings, then select Dynamic input tab and pick on "Settings" button under "Pointer input" :
Activate "Relative coordinates" option active in "Format" section:
Save settings with OK button.
2/ After you complete distance measurement, you can exit MEASUREGEOM command with Esc key or by selecting "eXit" option:
Command:
MEASUREGEOM
Move cursor or [Distance/Radius/Angle/ARea/Volume/Quick/Mode/eXit] <eXit>: d
Specify first point:
Specify second point or [Multiple points]:
Distance = 100.0000, Angle in XY Plane = 0, Angle from XY Plane = 0
Delta X = 100.0000, Delta Y = 0.0000, Delta Z = 0.0000
Enter an option [Distance/Radius/Angle/ARea/Volume/Quick/Mode/eXit] <Distance>: X
Command:
Maxim Kanaev
Architect
MARSS
