m41202722
331 Vistas, 6 Respuestas
Issue publishing pdf after softwere update
Issue publishing pdf (it just takes lots of time and it comes back without publishing) and sometimes some the command on the bar disappear after my last softwere update for my macbook pro (macOS Sonoma 14.4.1)
maxim_k
en respuesta a: m41202722
Hi @m41202722 ,
What AutoCAD for Mac version do you use?
Have you installed latest Update which fixes compatibility issues with macOS 14 Sonoma?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
m41202722
en respuesta a: maxim_k
Hi  maxim_k.
Thanks for your answer
I use the latest version Autocad LT 2025  trial version. I tried to uninstall it and install it back but the problem persists
maxim_k
@m41202722 ,
How do you publish?
Do you publish only one layout or you use batch publish?
Do you have this problem only in one of your drawings or in all drawings?
If only in one drawing - can you share it here?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
m41202722
-It doens't work even exporting just one pdf. I tried with export to pdf and publish, none of them work.
-All of the drawings and I also tried different files and it does not work. The problem started when I updated the new softerwere for macbook pro macOS Sonoma 14.4.1 (23E224)
Also, sometimes the bar appear like this but nor always. The main issue is still exporting pdf
m41202722
I normal bath publish to include more pages on the pdf but also exporting just one pdf is not working. The circle appears like to wait but then it comes back to the original page after a while. Sometimes I have to restart autocad
wei503
@m41202722 can you please share the settings below from the Publish dialog?
Wei Ma
AutoCAD QA Manager
