liamrobertsSP
173 Vistas, 1 Respuesta
Reformatting Data Links
I have linked data from an excel sheet which has all worked well but unfortunately the Date links across as mm/dd/yyyy and I would like it in dd/mm/yyyy format. It is in the dd/mm/yyyy format in the excel document but not AutoCAD?
maxim_k
en respuesta a: liamrobertsSP
Hi @liamrobertsSP ,
If I use these settings for datalink when I insert it to a drawing:
I get correct results:
Please pay attention to the note in the "Format cells" dialog in Excel about date formats with *.
If you select such date formats (with *) in Excel, they "respond to changes in regional date and time settings that are specified for the operating system."
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
