maxim_k
en respuesta a: jessicatorode88
Hi @jessicatorode88 ,
Just because a button doesn't have an icon doesn't mean you can't use it.
When you customized Tool Sets palette, you used standard AutoCAD command macro, defined in CUI file, but both Lineweight and Linetype command macros in AutoCAD standard CUI file don't have icons assigned.
You can verify this in CUI editor:
 If you want to have icons for these commands, you need to create custom command macros and add icons to them in CUI editor. Then you can add these custom commands to the ToolSets palette.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
