maxim_k
en respuesta a: pauljj1977
Hi @pauljj1977 ,
It's not entirely clear from your question what you want to do.
If you need to get a flat projection, then you can use the FLATTEN command, which is destructive to 3D object
or FLATSHOT command which simply creates 2D projection while leaving the 3D objects untouched.
Can you share screenshot or drawing itself with additional comments?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
