maxim_k
en respuesta a: UNKNOWN.DESIGN.LAB
Hi @UNKNOWN.DESIGN.LAB ,
As I suspected - your drawing is not flat.
When you measure distance between two point with DIST or MEASUREGEOM command you get the real distance in 3D space, but when you use DIM command you get the distance between projection of the points to the XY plane of the current UCS:
I also attached your drawing with yellow triangle which demonstrates these distances.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
