MKAA2
681 Vistas, 9 Respuestas
Fields formula for multiple areas
I switched from AutoCad on Windows to the Mac version, and there is one feature that I fail to reproduce on this version that is very important to me.
On the Windows version, I was able through the Fields feature to select the area of an object (a polyline in my case), copy paste the Field Expression on the Formula section of Fields, then go back to select another polyline, copy paste the Field Expression etc... and at the end I could find the addition of all the surfaces. The problem is, on the Mac version nothing is clear at all. Each time I try to copy paste the Field Expression of a poly line on the Formula section, the previous Field Expression of the previous polyline disappears, and I can never add up one area to another. It is very helpful to me to be able to know the exact surface of an apartment and I have no idea how it works on the Mac version (and if it is available on it ?).
Thanks in advance for your help!
