jatBYJCA
519 Vistas, 8 Respuestas
Curved lines in pat files show staggered
I downloaded a .pat file for landscape plans, but curved lines show as staggered when I import them to autocad.
This is the preview from the website I downloaded the .pat file from:
And this is the same pattern in AutoCad:
What am I doing wrong? Is there a way to fix this?
I've tried exploding and redrawing, but nothing happens.
Etiquetas (3)
maxim_k
en respuesta a: jatBYJCA
Hi @jatBYJCA ,
How far is this HATCH object from 0,0 of the current coordinate system?
If it is too far, AutoCAD cannot draw lines inside hatch correctly.
You need to move the hatch area closer to the current UCS or WCS origin or set UCS origin point near the hatch area.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jatBYJCA
en respuesta a: maxim_k
Hi Maxim,
Not far. I tried drawing a rectangle with one corner in 0,0 now with the same error:
I'm drawing in millimeters and the rectangle is roughly 65x65mm big.
maxim_k
@jatBYJCA ,
Can you share this PAT file?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jatBYJCA
Absolutely!
For some reason I wasn't able to attached it here, but see if this wetransfer link works?
https://we.tl/t-WkqDYe7yo1
pendean
@jatBYJCA wrote:
Absolutely!
Thanks for sharing the PAT file: it looks to badly written/coded for a 1x scale, it look the same here for me
Unless you set the scale to be really small (1/10 scale below, same rectangle)
maxim_k
At first glance it seems that such lines are included in the pat file.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
jatBYJCA
en respuesta a: pendean
Ah.. That's annoying.
I was hoping to use AutoCad to convert the pat-files to dwg so that I could import them to ArchiCad and use the hatches there. But I guess not!
Thank you!
jatBYJCA
Thanks Maxim!
I'll contact the site I downloaded it from.
