pendean
en respuesta a: andygnzllz9
A .dwg file can only be set to use STB or CTB, never both at the same time.
And AutoCAD for MAC cannot convert a .dwg file from one to the other in the file: a limitation Autodesk has not addressed yet. But you can do this to convert your .dwg file https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-use-CONV...
