andygnzllz9
240 Vistas, 1 Respuesta
AUTOCAD MACBOOK- CTB NO WORKING
I have a problem with the nibs when printing from dwg to pdf on macbook, my version is 2024, and it does not recognize any ctb files, only stb. PLEASE I NEED HELP!!!!!!!!!!!!! thanks
Etiquetas (1)
pendean
en respuesta a: andygnzllz9
A .dwg file can only be set to use STB or CTB, never both at the same time.
And AutoCAD for MAC cannot convert a .dwg file from one to the other in the file: a limitation Autodesk has not addressed yet. But you can do this to convert your .dwg file https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-use-CONV...
