13809994921
817 Vistas, 8 Respuestas
Text cannot be selected
I want to edit the text, but sometimes the text cannot be selected, without any layer locking operations. I am only drawing in model space, and this happens more than 50% of the time.
Currently, my own solutions are:
1. Press Ctrl+A, then Esc key, and then the text can be selected. However, this method does not work for vertical text.
2. Zooming in or out with the mouse wheel will most likely allow selecting the text for editing.
3. Use the "re" command to regenerate the model so that you can select and edit the text.
Other attempted solutions are:
1. The graphics engine used is Metal, if switching to OpenGL, all the texts in the drawing disappear and can only be displayed when hovering over them with the mouse. This also solves the problem of text not being selectable.
2. Using a non-"2D wireframe" view can also solve the problem. However, it may cause slow performance for bulk operations and lagging.
Etiquetas (1)
Etiquetas (1)
maxim_k
en respuesta a: 13809994921
Hi @13809994921 ,
Please specify your Mac model, AutoCAD for Mac version and macOS version installed on your Mac.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
13809994921
en respuesta a: maxim_k
macbook pro 2021 (M1 pro 16+1T)
autocad2024 education
Sorry, my English sucks
maxim_k
And macOS version is - ?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
13809994921
macOS Sonoma 14
maxim_k
Have you installed >>>>THIS<<<< Update?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
13809994921
I'm not quite sure, I'll confirm again tomorrow, but my updates are automatically opened; The updated content seems to be different from my question
13809994921
I'm not quite sure, I'll confirm tomorrow. Thank you very much
13809994921
Thank you very much for your help. I found that it was because of the font. If I change to a font like Arial, this issue won't occur, but after replacing the font, the drawing becomes unrecognizable. The Chinese "宋体" font will cause this problem.
