pendean
en respuesta a: Andrew.RobinsonXU922
@Andrew.RobinsonXU922 Your screenshot shows you are trying to create an STB plot style table (also found in Windows versions of AutoCAD): but it sounds like you've never used anything other than a CTB plot style table perhaps (also used/found in Windows and Mac versions of AutoCAD).
And if you never knew it before today, a DWG file only looks and can use one of those at a time. But MAC versions of AutoCAD cannot convert a DWG from STB to CTB, you sort of have to do it the long way as described here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-use-CONV....
